Clutch+water= bad - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-05-2002, 05:16 PM Thread Starter
Clutch+water= bad
Theres a water hole across form the punchout shack at work. And I like to play around a bit in it with my 72, never went all the way in before.But now with my 38's, I said "hey, ill go through and come out the other side" , well I got right in it, an started to sink in the silt at the bottom, I jammed for reverse, and the clutch pedal hit the floor, no movey da truck. So water stated comin in the cab cause it was four feet deep, and up to the bottom of the seat, so i climb in the back and start to hook the cable up, and a buddy saw me and had a camera, (pics later)anywho, he drug me out with the loader, and the truck still wont move.Dam, the linkage looks fine so it needs a clutch, gonna drag it inside tommorow and check it out a little more. At least its clean to work on now. Any tips on how to keep water out a little better would be appreciated.
ben427 is offline
post #2 of (permalink) Old 10-05-2002, 05:46 PM
Re: Clutch+water= bad
Umm, got a question here... Ok, what would water have to do with the clutch pedal going to the floor? If water got on the clutch, wouldn't it just cause it to slip a little bit but grab just like normal a second later than normal? If the pedal goes to the floor, and it's a mechanical linkage, not a master/slave cylinder setup, I would think it's a linkage problem or the clutch fork or clutch itself busted. Anyway, just wondering...
Best Auto Insurance | Auto Protection Today | FREE Trade-In Quote
willyswanter is offline
post #3 of (permalink) Old 10-05-2002, 06:02 PM Thread Starter
I was just thinking about that while watching reservoir dogs, im starting to think the throwout bearing flew apart, which would make the pedal go to the floor, but would leave the clutch engaged, but it still wanst moving, so its still gotta come apart. [img]images/graemlins/crazy.gif[/img]
ben427 is offline
post #4 of (permalink) Old 10-05-2002, 06:52 PM
Sounds like a linkage problem, but then I dunno what the pedal feels like.
Really want to see those pictures though [img]images/graemlins/laugh.gif[/img] hopefully water didn't go anywhere else it isn't suppose to go.
post #5 of (permalink) Old 10-05-2002, 07:01 PM Thread Starter
my vents are plenty high, so im not concerned, just the darn clutch, the visible linkage is fine, so its in the bellhousing definatley. I hope those pics come out too, i need pics of that truck cause i got none. it was quite a sensation i must say, being 40 inches off the ground and have the cab full of water [img]images/graemlins/cool.gif[/img]
ben427 is offline
post #6 of (permalink) Old 10-05-2002, 09:11 PM
Carpal \'Tunnel
wrath's Avatar
Does the pedal feel normal?
You might have tossed one of the springs on the plate. I did that on my Sonoma and the guy at the shop said he'd never seen anything like that before. It was the side effect of doing something similar to what you did, only it involved snow and 600lbs of sand in the back of my truck.
wrath is offline
post #7 of (permalink) Old 10-05-2002, 11:56 PM
it was the exact same...only completely different [img]images/graemlins/laugh.gif[/img]
sorry I just found it amusing
post #8 of (permalink) Old 10-06-2002, 08:22 AM Thread Starter
No the pedal is light pushing a feather nothing there at all. goes right to the floor, i think the only reason it comes back up is the spring my uncle put on the linkage.
Rusty, I see no difference in throwing the clutch in a sonoma with (presumably) stock tires and 600 lbs of sand in the back and me doin it i 4 feetof water in a K20 with 38's [img]images/graemlins/grin.gif[/img]
ben427 is offline
post #9 of (permalink) Old 10-06-2002, 08:56 AM
Carpal \'Tunnel
wrath's Avatar
You might've broken a clutch fork but it does sound like the throwout bearing went AWOL. If it was the pressure plate ears or a spring in the friction disk then it'd feel funny and probably always stay partially engaged.
I did it in my Sonoma which still had the 31x10.50s on it (sno snow tires not on yet). I was going 8-10 miles an hour when I threw it in reverse and dumped the clutch. The truck hopped all over the place and I'm surprised I didn't ruin a whole lot more. I was coming up to an intersection that was all ice/slush and a car was sliding through a stop sign and I knew I wouldn't be able to stop once I left the good asphalt I was on. The person ended up sliding sideways into a pole.
wrath is offline
post #10 of (permalink) Old 10-06-2002, 12:04 PM
Sounds like the fork to me. I have seen the fork slide out of place if you dont have a spring holding tension on it, the fork can slip out of place on the indexing ball in the bellhousing and fall off the throwout, but this is rare. If this was the case, sometimes you can wiggle the fork around and get it lined back on the throwout by feel. I was able to do this once, but the other time I had to pull it apart to get everything lined back up. Good luck. by the way get those pics up-sounds like a cool truck.
