gear ratios??? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 09-17-2002, 10:05 PM Thread Starter
gear ratios???
i was just wondering if anyone knew what K10s came from the factory with, im guess 3.73s but im not sure, also would 14 bolt SFs come from the factory with the 3.73s also?
Drey is offline
post #2 of (permalink) Old 09-17-2002, 10:28 PM
Re: gear ratios???
Over the years K10's have been available with 2.73, 3.07, 3.42 and 3.73 ratios. The majority will probably have a 3.07 ratio and then the 3.42's became a more popular at the end of the body style in the 88 - 91 Blazers and Subs.
The 14 bolt SF could also have a wide variety of ratios from 3.42, 3.73 and 4.10, I think 3.42 and 3.73 were the most popular with them.
post #3 of (permalink) Old 09-17-2002, 11:33 PM
AzzKicker
Re: gear ratios???
YA, my 85 GMC w/305 came with 3.08's or 3.07's Talk about CRAPPY acceleration. Thank god for the 700R4 low 1st.
post #4 of (permalink) Old 09-18-2002, 08:59 AM
AJMBLAZER's Avatar
Re: gear ratios???
Check your glove box codes. The way your truck sounds I doubt anyone has swapped the gears.
AJMBLAZER is offline
post #5 of (permalink) Old 09-18-2002, 08:37 PM
Re: gear ratios???
yeah, I had an '84 w/ 305 and 2.73's
post #6 of (permalink) Old 09-18-2002, 09:17 PM Thread Starter
Re: gear ratios???
no glovebox codes, ive looked for them before they dont exist in this peicer [img]images/icons/crazy.gif[/img] im gonna assume it came with 3.73s cuz thats what my C10 deisel had
Drey is offline
post #7 of (permalink) Old 09-19-2002, 09:07 AM
Re: gear ratios???
nvrenuf hit it right there .. there are all manner of possible ratios. If you are not sure what it is then your best bet will be to pull the cover and look for the #'s stamped into the ring gear. Post the #'s here and someone wil be able to decode them for you. Most importantly you'll be able to check out the gears and do some easy (and probably needed) maintenance.
post #8 of (permalink) Old 09-19-2002, 09:22 AM
Re: gear ratios???
on the ring gear are a set of numbers. Generally the last 2 set of the devide the first by the second and that will tell you. 41 10 would be 4.10:1 gears.
post #9 of (permalink) Old 09-19-2002, 04:42 PM
427jimmy
Re: gear ratios???
Another way to do it is to jack the vehicle up so that both tires are off of the ground. Have an assistant turn the drive tire 1 full turn. Count the number of times the pinion rotates. 3.42 would be 3 and almost a half turns of the pinion. 4.10 would be 4 turns and a little bit. Might take a couple of tries but it does work. And is the easiest way to do it without removing the cover.
post #10 of (permalink) Old 09-19-2002, 09:25 PM Thread Starter
Re: gear ratios???
ok, ill try that tmw before the football game, a little before 4 turns is 3.73s right?
Drey is offline
