fly wheel spacer?? anyone ever heard of? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-21-2002, 05:59 PM
thats what happens when you mix and mach,
has anyone ever seen a flywheel spacer? if so can you point me in a right direction?
im trying to put a LS1 and NV4500 together, i really want to use the truck flywheel, since the LS1 fly wheel costs 400 bucks new, and if i use the trany one i can bolt them together, if not i have to try and fit a nv4500 clutch between LS1 press plate and fly wheel, more problems...
so basicly the deal is that the "outer rim" on the fly wheel scrapes the block when i put it on, it seemses that it would be perfectly fine if i can move it away from the block by use of a spacer, haven't measured yeat but an 8th should do the trick, has enyone seen those, or do i fab one up? anyone think its a bad idea?
post #2 of (permalink) Old 08-21-2002, 07:23 PM
Re: fly wheel spacer?? anyone ever heard of?
Flywheel is somewhat of a taper fit on the crank flange isn't it??
Cause of the taper I would imagine a spacer is not a safe way to do it.
beaterchevy is offline
post #3 of (permalink) Old 08-22-2002, 06:38 PM
yeah it is, so i would have to get one machined that would exactly duplicate the end of the crank shaft, if thats possible at all... that kinda sucks, i can't think of anyother way to do it at the moment, ill try using ls1 fly wheel, maybe i can find a used one...
post #4 of (permalink) Old 08-23-2002, 09:25 AM
87sm465np208
nay, but i have heard of flywheel shims that will give you about .025 i think, but i know flywheel shims exist, look into it, it might be your answer.
post #5 of (permalink) Old 08-23-2002, 10:50 AM
<font face="Times New Roman"><font color=green>Don't know how much you'd be willing to spend, but I did some searching and found a used one in Michigan for $250.
Weller Auto Parts - Grand Rapids USA-MI(Grand-Rapids) 1-616-538-5000
Shaggy is offline
post #6 of (permalink) Old 08-23-2002, 06:00 PM
it would take a crap load of those shims, i would reather make it one piece.
thanks shaggy but ill find one localy, i want to make sure it works in the first place, if not i want to be able to return it or swap it for something else.
