Dodge axles? Steering...
505 views 2 replies 2 participants last post by  MIJeepBoy
I am almost for sure getting a SFA S10 Blazer on a FS frame, its got Ford axles/divorced t-case. He wants the axles and t-case, so i need to do some work... I have a set of 3/4 ton axles (44 front, FF 60 Rear). What are the possibilities of the steering working without much work? Anyone with experience?
#2 ·
If the ford front axle is a dana, then the hooking everything up shouldnt be too bad. I dont know much about fords, but i think that they all use dana 44's also. The steering on the two would be the same.
#3 ·
Good deal. So, I have the steering arm on the axle and the tierod... And the truck has an arm off the steering box, so I need that small tierod or whatever its called to link the two? Could I get that off a Ford, Chevy, Dodge (are they all the same if its Dana?)?
