u-joint problem - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-22-2002, 01:37 PM
u-joint problem
I have an 89 k-5 blazer with a 350 and 3 inch lift with 33X12.50X15 tires on it. My question is this, I had the u-joints replaced around 6,000 miles ago and they are going bad again on my rear drive shaft. Does anyone have any idea why they may be going bad so early? Any help would be appreciated. I had them put in by a mechanic and i keep them greased also
post #2 of (permalink) Old 04-22-2002, 08:21 PM
Re: u-joint problem
Check your driveline angle. Unless you have a CV joint rear drive shaft, your pinion u-joint angle should match your t/c u-joint angle within a degree or 2.
rx7xj is offline
post #3 of (permalink) Old 04-25-2002, 08:22 PM
Re: u-joint problem
Did you lower your tcase after the lift? There are two spacers on the bolts that mount the crossmember to the frame. Move them so they are between the crossmember and frame so the case is lowered. Also, do you have shims under the rear springs? These things will help you get better angles and make your u-joints last longer.
90K5 is offline
post #4 of (permalink) Old 04-25-2002, 10:27 PM
Re: u-joint problem
sorry i should have posted that i have a 3 inch body lift...would i still need to do all that? I think I asked before and everyone said i didn't. anyway thanks for the help
post #5 of (permalink) Old 04-26-2002, 09:40 AM
Carpal \'Tunnel
wrath's Avatar
Re: u-joint problem
No, your driveline is still the same.
It certainly is peculiar.
Do you have a lot of axle wrap? I've notice some older pickups are starting to get the infamous pinion-down syndrome.
By any chance is your frame bent or "dogtracking"? You should be able to look from the back of the truck at your transmission and be able to imagine a straight line between your crankshaft and your pinion shaft. If it isn't straight it can cause transmission cases to break and universals to wear out.
wrath is offline
post #6 of (permalink) Old 04-26-2002, 11:42 AM
Re: u-joint problem
My 1982 K5 use to eat U-joints ALL the time. The problem with my truck turned out to be a bad pinion yoke on the rear axle. One of the U-joints that blew lost a cap on the yoke side and the torque of the driveshaft drove the inside bearing surface of the U-joint into the yoke, putting a hell of a divot into the yoke itself. I didn't notice this right away... I'd get a couple thousand miles on the U-joint, then KA-BAM! I finally saw the dent when I was replacing a U-joint. Replaced the yoke and problem fixed.
