fault codes - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-29-2001, 11:17 AM Thread Starter
fault codes
I got a obd2 tester yesterday, cool stuff! The trouble code that made my check light come on was P0327 (Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)). Does anyone know what this means and how to solve the problem???
1996 2Dr. 4X4 Tahoe, 350 Vortec, 3.73 gears, Magnaflow 3" Catback, Airaid Intake, and a bent front diff. skid plate! (Stock susp. on 265's)
cspringer8 is offline
post #2 of (permalink) Old 08-29-2001, 12:28 PM
Shorts's Avatar
Re: fault codes
the knock sensor retards ignition timing during spark knock to let the ECM hold max timing advance in most conditions.
test:
- connect timing light to vehicle and start the engine
- check that timing is correct before testing sensor
- if timing is correct, tap on the front of the engine block with a metal object while observing the timig to see if it retards
- if the timing does not retard, the knock sensor may be defective
if you need to replace it, use a water base caulk on the threads. do not use teflon tape because it'll insulate the sensor from the block.
btw, the sensors is right in front of the starter, on the engine block.
<font color=blue>Shorts</font color=blue>
Your what is stuck? [img]/wwwthreads_images/icons/crazy.gif[/img]
Shorts is offline
post #3 of (permalink) Old 08-29-2001, 01:08 PM
Re: fault codes
WTF, shorts? where do you get this stuff. did you design and build all of our trucks or something?
---Peacock
<font color=red>96 Z-71 EXTcab, richmond 3.73, detroit rear, cold air, dual flowmasters, new drive-train </font color=red>
u4ia4 is offline
post #4 of (permalink) Old 08-29-2001, 01:14 PM
Shorts's Avatar
Re: fault codes
nahhh, i just read to darn much [img]/wwwthreads_images/icons/tongue.gif[/img]
Shorts is offline
post #5 of (permalink) Old 08-29-2001, 01:20 PM Thread Starter
Re: fault codes
Great, thanks for the info, where can I find that kind of info on my own??? Give us the good beta, man!!
post #6 of (permalink) Old 08-29-2001, 01:22 PM
Shorts's Avatar
Re: fault codes
chilton's [img]/wwwthreads_images/icons/blush.gif[/img] [img]/wwwthreads_images/icons/laugh.gif[/img]
Shorts is offline
post #7 of (permalink) Old 08-29-2001, 01:22 PM Thread Starter
Re: fault codes
Hey Shorts, the obd2 tester gives a realtime readout for timing, can I use that instead of using a timing light???
post #8 of (permalink) Old 08-29-2001, 01:25 PM Thread Starter
Re: fault codes
I tryed to buy a Chilton's on the way to work, they weren't open yet. I will get one tonight, good to see that they cover this stuff in there.
post #9 of (permalink) Old 08-29-2001, 02:08 PM
Shorts's Avatar
Re: fault codes
i'd say so. the only thing you're looking for is whether the timing retards or not...it shouldn't matter how you're reading the timing.
just make sure you can read the scanner and tap on the block at he same time [img]/wwwthreads_images/icons/crazy.gif[/img]
Shorts is offline
