No Spedometer...HELP!!!!! - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-22-2001, 03:44 PM Thread Starter
Well, the last little while I have been having some electrical problems such as no day time running lights and stuff and I finally have them all fixed exept now my speedo doesn't work[img]/wwwthreads_images/icons/frown.gif[/img]
I have searched everywhere and tested everything that I can and I can't find power to anything other than the fuse panel "guages". There is no power at the conection on the T-case, no power at the vehical speed buffer and there is none up top at the cluster. I have the whole truck wripped apart as I speek. Does anyone know where the speedo gets power from????
Someone out there must know whats wrong....Ryan
93 GMC Yukon
Chevy SuperStock 4x4 Truck Puller
Great Lakes Truck & Tractor Pulling Association
http://www.greatlakespull.com
RyanB is offline
post #2 of (permalink) Old 08-22-2001, 05:01 PM
Shorts's Avatar
Re: No Spedometer...HELP!!!!!
i'm guessin' this is on your '93 yukon?? well, let me search the chilton's here...
are all the grounds secure?? no codes?
ok..i have the diagram here. i'm going to draw it up and post it for you. give me a few minutes...
<font color=blue>Shorts</font color=blue>
Your what is stuck? [img]/wwwthreads_images/icons/crazy.gif[/img]
Shorts is offline
post #3 of (permalink) Old 08-22-2001, 05:45 PM
Shorts's Avatar
ok, here's a blurry drawing of the wiring... [img]/wwwthreads_images/icons/crazy.gif[/img]
C8: BLK/WHT ---> TO ENGINE GROUND
C9: BRN ---- FUSE #18 (10A) --> TO IGNITION SWITCH
C10: WHT ----> TO ANTILOCK
C11: DK BLU ---------------- F13 VEHICLE SPEED SIGNAL
C12:
C13: BRN --------- F12 TRANSMISSION OUTPUT SPEED
C14: DK GRN/WHT ----> TO CRUISE CONTROL
C15: DK GRN ---------------------> TO SPEEDO
Shorts is offline
post #4 of (permalink) Old 08-22-2001, 07:01 PM Thread Starter
Thanks Shorts[img]/wwwthreads_images/icons/wink.gif[/img]
Actually there are 2 codes comming up which I can't find in my manual. Code 35 and code 75. My maual (I forget which one it is) has pretty well every code exept those two.
It all started yesterday when I was fixing the DRL's under the dash. Not sure if I knocked a ground off somewhere or pulled out a wire.
Thanks...Ryan
93 GMC Yukon
RyanB is offline
post #5 of (permalink) Old 08-22-2001, 10:25 PM
Shorts's Avatar
Ryan, i have the codes but they're listed as through '95 with 4L60E tranny...
anyhow, you might want to check it out as you might have a crossover year truck.
code 35: IAC
probable cause: IAC error
testing: using ohmmeter measure R between IAC terminals A and B....then measure R between C and D. verify that R is between 20-80 ohm.....if not, the IAC may be bad. now measure B and C...then A and D. the R needs to be infinite...if not, the IAC may be faulty.
code 75: System Voltage Low
probable cause: system voltage < 7.3 at low temperature or < 11.7 at high temperature for 4 seconds.
Shorts is offline
