NV4500 - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-08-2001, 05:19 PM
Kendog454
NV4500
Are all the trannys in full size trucks after '91 the NV4500? And, is this the tranny with the low 1st like the 465 and the overdrive?
1985 Scottsdale 3/4 ton
14 Bolt SF, SM465/208, 355 CHEVY
post #2 of (permalink) Old 08-08-2001, 10:35 PM
desertrat67's Avatar
Re: NV4500
no, chevy also used a getrag and the nv3500(i think)
pics of the V30 which is still for sale or possible trade.
desertrat67 is offline
post #3 of (permalink) Old 08-09-2001, 11:44 AM
72dreamer
Re: NV4500
NV4500 came out in '92 3/4tons and some 1/2 tons with tow packages.
you can find an nv4500 with a 1st of 6.34:1.
Marriage is like a skin graft, it may or may not take.
post #4 of (permalink) Old 08-10-2001, 11:50 AM
u2slow
Re: NV4500
NV4500's come in 91-up heavy 3/4-tons and 1-tons - 8600lb GVW and over. The only exception I'm aware of is a lighter truck with a diesel.
The NV4500 has a low first gear like the SM465. 6.34:1 for 91-94. 5.61:1 for 95-up.
'91 V3500 Crewcab, bobbed, SM465/NP205, D60/14FF, 4.10, 12k Warn, dual batts, 2" body, Blazer fuel tank.
post #5 of (permalink) Old 08-17-2001, 12:16 AM
Re: NV4500
The heavy GVWR trucks used the 4500 starting in 93 or so. The 4500's built before 95 had a 6.34 1st, and the 95 and later trannies had a 5.61 1st gear. Most of the LD trucks had Getrag 4 and 5 speeds until 93, and the NV3500 starting in 94. They are basically the same tranny with different names and are all junk. Some light duty trucks (including the ones with HD towing packages) had the 4500, but thats a rare find. For more info on the 4500, check out Advance Adapters.
Bowtiepower00 is offline
post #6 of (permalink) Old 08-17-2001, 05:53 PM
u2slow
Re: NV4500
The NV3500 started in 93 replacing the Getrag. Both it and the Getrag have 5 speeds and an integral bellhousing. These two are the light-duty 5-speeds.
The 4-speed used up to and including 91 is an SM465, not a Getrag. CK models got the aluminum-topped version, RV models (like my truck) got the iron-topped version.
The NV4500 did in fact appear for the 91 model year - only in the CK series however.
post #7 of (permalink) Old 08-17-2001, 11:08 PM
Kendog454
Re: NV4500
How do the NV3500 and Getrag compare to the 4L60E?
post #8 of (permalink) Old 08-17-2001, 11:22 PM
Re: NV4500
The one (NV3500 and the Getrag) you have to push in a pedal and then shift gears with this stick coming out of the floor. The other you put your foot on the brake and then pull a lever on the steering colum down puting it into gear.[img]/wwwthreads_images/icons/wink.gif[/img]
Anyway....sorry about that little joke. The Getrag is a manual trans and the 4L60E is an auto.
Ryan
93 GMC Yukon
Chevy SuperStock 4x4 Truck Puller
Great Lakes Truck & Tractor Pulling Association
http://www.greatlakespull.com
RyanB is offline
post #9 of (permalink) Old 08-18-2001, 09:59 PM
Kendog454
Re: NV4500
I know that I meant in strength and durability. (i.e. would I be better off beating on a NV3500/Getrag or on a 4L60E??)
