8 inch rim - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 08-05-2001, 12:23 AM
8 inch rim
Does anyone know if you can run a 12.5 33 tire on a 8 inch rim?
97 2dr Tahoe,All terrains,Flowmaster, more to come.
post #2 of (permalink) Old 08-05-2001, 02:37 AM
Re: 8 inch rim
Sure, it is likely the recommended rim too.
http://www.cirent.com "Bubba Tub" 1977 K10 d60-14ff Np203,th350,350 Stock,6" lift,39.5" SS
post #3 of (permalink) Old 08-05-2001, 08:08 AM
Shorts's Avatar
Re: 8 inch rim
yeah, 8" with work fine. it cuts down on the dreaded width problem that causes tire rubbin' in chevys [img]/wwwthreads_images/icons/crazy.gif[/img]
<font color=blue>Shorts</font color=blue>
Your what is stuck? [img]/wwwthreads_images/icons/crazy.gif[/img]
Shorts is offline
post #4 of (permalink) Old 08-06-2001, 12:06 AM
Re: 8 inch rim
Thanks for the help and for telling me exactly what i wanted to here.
post #5 of (permalink) Old 08-07-2001, 01:00 AM
Re: 8 inch rim
As they said you can run a 12.50 wide tire on a 8 inch rim, but from what I have seen it will tend to bow the center of the tire out causing the center to wear out faster than with a 10 inch rim.
Just my $.02.
If it aint broke, keep fixing it till it is.
HighSierra is offline
post #6 of (permalink) Old 08-07-2001, 01:39 AM
Re: 8 inch rim
So, if I decide to get some 15" rims and put 33x12.5's on them, then I should go with a 15x10 instead of 15x8?
Anyone got tips/suggestions on this?
Will it be OK with my 4" lift?
I plan on using the 15" wheels if I decide to do some more mods in the future (i.e. my dreams[img]/wwwthreads_images/icons/wink.gif[/img]) to let me run 35+ tires
JaxZ71
94 Z71 350, Xcab, Sportside, 285/75/16 BFG AT, 16x8 AR Nitro, K&N, MSD coil & wires, Trailmaster 4" lift.
Lousy glasspacks and rusted Westin step bars [img]/wwwthreads_images/icons/frown.gif[/img]
JaxZ71 is offline
post #7 of (permalink) Old 08-07-2001, 06:50 AM
Re: 8 inch rim
I run 315-75R16's 35-12.50's on my truck, they are mounted on Eagle 058 16x8 rims. They fit great and the contact patch at 50 PSI looks good. If you go with the 8" rims, you can change tire size later if you want and not have to worry about getting narrower rims.
Doofuss
post #8 of (permalink) Old 08-07-2001, 09:47 AM
Re: 8 inch rim
I was also told that 8" rims are actually what 33 x 12.50's were designed for. Running the correct tire pressure will insure flat even wear. The 8" rims also cut back on rubbing which 10" rims are notorious for. If I ever get a suspension lift and can run 35's I'll still probably stick with 15 x 8's to cut down on rubbing...
- Rick - 98' GMC X-Cab Z-71 33 X 12.50 BFG MT, 2" Body Lift
post #9 of (permalink) Old 08-07-2001, 12:24 PM
Shorts's Avatar
Re: 8 inch rim
8"s are what i'll go with as well....whether they be 15x8 or 16x8.
Shorts is offline
post #10 of (permalink) Old 08-07-2001, 01:12 PM
Blazer1970
Re: 8 inch rim
There is no problem adjusting air pressure to get a proper contact patch with a 12.50 tire on an 8 inch rim. Use 8 inchers unless you plan to go to a 14.50 or wider tire.
'70 CST Blazer, 350, SM465, NP205.
'87 Suburban 4X4, 350, 700R4
'01 GMC 2500HD, Duramax/Allison
