I'm bored at work can you tell??
http://www.Wrenchead.com
Napa TEM271283 $569.00 $40 core
napa remanufactured TEM251283 $ 364 40 core
AC delco new ACD1520151 $ 749.50
http://www.carparts.com
AC DELCO 15-20151 $501.60
FOUR SEASONS 57950 $276.76
http://www.autozone.com
FACTORY_AIR REMANUFACTURED 57950
1 YR war. $10.00 core $219.99
AC-DELCO NEW 15-20151
1 YR war $369.99
FACTORY_AIr
NEW 58950
1 YR $349.99
AC-DELCO
REMANUFACTURED 15-20421
1 YR $244.99
1 YEAR COMPRESSOR WARRANTY VALID ONLY WITH REPLACEMENT OF RECEIVER DRIER AND ORIFICE TUBE OR ACCUMULATOR
Inspect
BELT
Incorrectly routed, adjusted(tensioned), missing or worn drive belt(s).
3
Inspect
A/C CLUTCH COIL
Damaged or faulty air conditioning clutch coil (fails to energize and engage air conditioning clutch).
4
Inspect
A/C CLUTCH
Air conditioning compressor clutch not engaging.
5
Inspect
A/C COMPRESSOR
Refrigerant in system is low, contaminated, or restricted.
6
Inspect
A/C COMPRESSOR & CLUTCH
Damaged or faulty a/c compressor and/or clutch, low oil level.
7
Inspect
A/C CONDENSER
Refrigerant in system is low due to leaking air conditioning condenser.
8
Inspect
A/C EXPANSION VALVE
Damaged or restricted air conditioning expansion valve or capillary tube.
9
Inspect
ACCUMULATOR
Damaged, clogged, or restricted A/C accumulator/receiver drier.
