HELP - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-28-2001, 12:48 AM
HELP
OK i have a problem, the other day my waterpump went out, 92 Z-71, i replace it and a gasket gets screwed up, then tonite i fix the gaskets. now my thermomoter, says my engines over heating. I think i screwed up the thermostat. Any help people can offer would help.
post #2 of (permalink) Old 06-28-2001, 01:32 AM
Re: HELP
try taking out the thermostat and see if it still overheats. if so, something with the waterpump is screwed up. are you sure you got the right one? reason i ask that is someone was posting about thermostats a few weeks ago and someone had an experience where they put the wrong pump in and it was reverse rotation of the other pump, this not allowing the thermostat to open. if removing the thermo fixes it, then that either means it was bad or the reverse rotation pump thing.
EDIT -- oh yea, ive also heard that when you drain your coolant (actually when you replace a thermostat), you should drill a small hole in the thermostat b/c sometimes steam will buildup under it and not allow it to open. might wanna try that first, its probably the problem
Mike ~
* Earnhardt Forever *
89 Chevy K1500 - 350TBI/700R4/NP241 - 3" lift - 33's - other goodies, but not enough! [img]/wwwthreads_images/icons/tongue.gif[/img]
post #3 of (permalink) Old 06-28-2001, 11:26 AM
Re: HELP
ok, i'm gonna work on it again today, but i gotta work tonight so i don't know how much i'll get done, thanx for the info though
post #4 of (permalink) Old 06-28-2001, 01:38 PM
Re: HELP
Just replace the thermostat. They're cheap anyways. Also, your temp sensor might be out. I have an older motor ('79) and it's on the side of the block. Not sure where yours is. It will be on the head prolly with a wire coming out of it. You also want to be sure you don't have air in your cooling system. Let it run with the cap off the radiator long enough for the thermostat to open.
post #5 of (permalink) Old 06-28-2001, 04:24 PM
Re: HELP
<font face="Comic Sans MS">First of all. Did you have your thermostat out?
Second of all. Check your belt routing. You might have gotten it on the wrong side of the pump which I think would mess up the rotation of the pump.
If your thermostat was working properly before the water pump, then double check to make sure you got the right pump. [img]/wwwthreads_images/icons/crazy.gif[/img]</font>
Tim "Sandman"
ORC Land Use columnist:
My May Column
The_Sandman_454 is offline
post #6 of (permalink) Old 06-29-2001, 12:13 AM
Re: HELP
Mud4fun was right on the money, i ran my truck with the radiator cap off today, and all this air came out, and now its working, but my thermostat keeps fluctating while i drive so i am just gonna replace it anyway. thanx for the help guys
post #7 of (permalink) Old 06-29-2001, 12:26 AM
Re: HELP
Hey Muddin!
Cheryle
You never really learn to swear, until you learn to drive!!!
shewheeler is offline
