Re: Dual Fuel Tanks
Your pre fuel injection so the switch only does two things (assuming you have a mechanical fuel pump on the block, if it has an aftermarket electric pump(s), it may do more). In normal applications the switch has 12 volts going to it, a sending wire (usually pink) going to the gas gauge, a wire going to the solenoid, and two sender inputs (one from each tank). The solenoid should have one wire going to it (the one from the switch) and it's self grounded. First check the ground on the solenoid (unbolt it, clean both mating surfaces, and rebolt it). Next take a test light and put it on the wire going to the solenoid. Then put the switch in the other direction and check it again. Assuming the ground it good, there should be power (12 volts) in one direction, but not in the other. If there is no power in either direction check the power going to the switch, if there is no power going to the switch, then a fuse is blown (change fuse)or you have a break in the wire (replace with jumper). If there is power to the switch, but none coming out when the switch is in either position, you have a bad switch (replace it). If you have power in one direction but the tanks won't switch, then you have a break in the wire (replace with a jumper) or you have a bad solenoid (replace). Another thing to check (non-electrical) is for plugged lines coming from one tank. If all electrical checks out you may have a blocked line. There are a couple more things to check and ways to check the solenoid for proper function. PM me if you have more questions. Hope this helps
If you didn't built it yourself, how can you call it yours.......
