Re: Body mounts need help
Loosen ALL body mounts, remove the bolts wherever required. Place a length of 4x4 between the jack and the body. Lift only one side at a time. Lift VERY SLOWLY and be certain to CONSTANTLY check for any wires, cables, hoses, etc. binding up. Lift only as much as necessary to replace the blocks. Then lower slowly, and tighten all bolts.
Good Luck!
1995 K1500 3"Suspension 3" Body Lifts 35x12.5x15's pro comp MT's on 15x8 Rockcrawlers 5.7L
