Re: Speed Governor
JET makes a piece called SCU 2000, you can get it at summitracing.com for $139 plugs in between the speed sensor on the auto trans for 96-2001 GM trucks. recalibrates for different tires, gears, and Removes the speed limiter. easy hookup powerwire, ground, and the plug in. 4 dials to set 1. stock tire size(off door if you dont know) 2. stock gear ratio (if you dont know look up code in glove box) 3. modified tire size (i had to do chalk line roll out and measure) 4. modified gear size. took about 1/2 hour to install part#50100
DJ
