crank up t-bars....what about the rear? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-16-2001, 11:38 PM
BigBlueZ71
Hey when I get my truck back i'm gonna crank up the Tbars a little. What do I do to the back to compensate a little??
-Ryan S- 1994 Chevy Silverado Z-71 Two-Tone Navy/Silver, 285/75/16 BFG Mud Terrains. Custom Flowmaster Dual Exhaust. K&N system. Custom Kenwood/Rockford Fosgate system, two 12" Rockford HE subs.
post #2 of (permalink) Old 06-17-2001, 12:05 AM
Re: crank up t-bars....what about the rear?
get a 1" ada leaf, AJM likes the zero rate leafs that give you about an inch of lift.
but you can probably go to anytire shop and pic a set up for 50 bucks or so and theyll also give you about 1" and increase your load careing capcity too, and may make your truck ride just a nough rougher to notice,
sometime this week Im throwing a set of 3/4 ton leafs with overloads on mine, I should gain a lot of load capcity and 1" of lift since 3/4 ton leafs have one more leaf than my 6lug 3/4.
IF ITS GOT WHEELS OR A SKIRT YOU CANT AFFORD IT
The_Kid is offline
post #3 of (permalink) Old 06-17-2001, 02:00 AM
AJMBLAZER's Avatar
Does your truck sit nose low right now? Our trucks came from the factory that way, so if it sits level now, I'd think someone has already cranked the torsions a little. You might want to check on that.
Still, if your truck is a little bit high on the front, I like the http://www.OffRoadDesign.com 1" zero rate add a leaves that I have. You can read a write up and install at http://www.coloradok5.com/ordaddaleafreview.shtml about them. Good stuff. 1" of height gain with none of the side affects of an old fashioned add a leaf. Doesn't up your load rating any, but your ride and flex stay the same.
1992 Blazer Sport, 350 TBI, 4L60, 3" Flowmaster, K&N, MSD coil & wires, Rancho 2.5" lift, 285/75R16 AT's[img]/wwwthreads_images/icons/laugh.gif[/img]
AJMBLAZER is offline
post #4 of (permalink) Old 06-17-2001, 10:55 PM
Tightening your torsion effects your allignment. If your not worried about screwing with the camber then go for it. You will cause premature wear on the outside edges of your tires and your steering wont act the same. Many guys talk about doing this but it doesn't make sense.
Joe
post #5 of (permalink) Old 06-17-2001, 11:00 PM
Park it facing down hill.
post #6 of (permalink) Old 06-17-2001, 11:09 PM
whitetail204
crankin the t-bars 1" isnt gonna hutr anything.Im interested in what AJMBLAZER was saying .I need a little lift in the rear also.
post #7 of (permalink) Old 06-17-2001, 11:10 PM
the tires will tilt in at the top wearing the inside edge,
1/2" of lift wont affect things a hole lot but any more and you can see the dif in camber, at least I can
And no cranking the t-bars wont wear the outside edge of the tire it will wear the inside edge. lowering the bars to much would wear the outside edge, I guess thats kinda trivial thought either way it will wear prematruley.
The_Kid is offline
post #8 of (permalink) Old 06-18-2001, 02:59 AM
Shorts's Avatar
kid, i'm going to have to disagree with you on that [img]/wwwthreads_images/icons/blush.gif[/img] cranking the bars too much will make the tires sit like this ----> \''''/
...the bottom of the tires are pointed in...
<font color=blue>Shorts</font color=blue> &lt;-- its not what you think...and don't ask what it is [img]/wwwthreads_images/icons/smile.gif[/img]
Shorts is offline
post #9 of (permalink) Old 06-18-2001, 10:26 AM
no, the the tires are in like this: /\ when you crank the torsion bars, and like this: \/ when you lower them. if you were to go do this right now to your truck, that is what it would look like. not trying to show you up or anything, its just that i am always lowering and raising the front end because of my stupid 2"-3" rough country lift.
post #10 of (permalink) Old 06-18-2001, 12:26 PM
Shorts's Avatar
no way.... they're the way I SAID IT! [img]/wwwthreads_images/icons/mad.gif[/img] [img]/wwwthreads_images/icons/shocked.gif[/img] [img]/wwwthreads_images/icons/tongue.gif[/img]
mine when 'bottom in' when i cranked them up....so, beats me...maybe mines broken???? [img]/wwwthreads_images/icons/crazy.gif[/img]
Shorts is offline
