oil pan troubles - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-08-2000, 02:14 AM
oil pan troubles
heres the deal on an of the line peadle to the floor board launch. I lose all oil pressure witch in turne shuts the motor doun for just a sec and then takes off again. this is caused from the oil being pushed to the back of the pan. heres the ? what type of windag tray should i get. i am gusseing the trap door. but not for sure. just dont want to buy what i dont need part numbers and dealers would be nice thanks. or cheape how tos would owrk also
If it has tits or tires it will give you trouble.
post #2 of (permalink) Old 10-08-2000, 07:35 AM
RolngThun
Re: oil pan troubles
If I understand your post correctly, you are having troubles with the oil running to the rear and up the pan under acceleration.
First of all it takes big time power and hook up to cause this trouble, and I do mean big time power.
So I would first make sure something else is not wrong,oil pump pick up came off or not correctly adjusted to the bottom of the pan. I had a car where the pick up came off, it would loose pressure when I braked hard. 69 Camaro when I was a kid, I bought a big Moroso pan and all and discovered the real problem when I changed the pan.
Otherwise, the swinging trap door is for deacceleration, what you would need is the baffle that bolts between the oil pump and the main cap. This blocks oil from riding up the back. It is very inexpensive. You should be able to find it in Jegs, Herbert, or Summit easy enough.
post #3 of (permalink) Old 10-08-2000, 11:08 AM
Are you sure it is due to oil climbing the rear of the pan? I used to drag race, and Holley carbs have a tendancy to slosh fuel out the vent on a hard launch. It causes the motor to stumble for a second then take off like a rocket. It is a simple fix, just add a pice of rubber hose to the vent stacks and tie it to the air cleaner stem.
