10 Bolt Axles - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 10-02-2000, 11:15 AM
10 Bolt Axles
Does anyone make a C clip eliminator kit for the later 30 spline 10 bolt rears?
post #2 of (permalink) Old 10-02-2000, 05:32 PM
Re: 10 Bolt Axles
No offence, but if you need to eliminate your c-clips, you need a stronger rear end. Its not going to last very long if your sending that much power to it. You should be able to find 12 bolts or even 14 bolts for pretty cheap, and they'll bolt right in. It'd maybe be worth spending the $$$ for a c-clip eliminator on one of those. Eliminating c-clips is not cheap. Whether or not they make a kit for it I don't know, but it can be custom done in any case, just more $$$. Talk to a rear end shop.
post #3 of (permalink) Old 10-02-2000, 05:36 PM
Re: 10 Bolt Axles
Sure, just get a Warn full floater kit. That'll eliminate those nasty C-clips.
http://OffRoadDesign.com had them listed on their page.
John
95.5 YJ with "stuff"
94 GMC Z71 without "stuff"
http://SonsofThunder4x4.com
RatherBeJeeping is offline
post #4 of (permalink) Old 10-02-2000, 06:45 PM
Re: 10 Bolt Axles
RatherBeJeeping is right. The only thing you can do to eliminate the c-clips on an off-road vehicle is to use the Warn FF kit. Standard c-clip eliminators, like Moser's, are for drag-race use only, they are not designed to withstand sideloading.
<font color=green>Evan</font color=green>[img]/wwwthreads_images/icons/crazy.gif[/img]
Shaggy is offline
post #5 of (permalink) Old 10-02-2000, 08:03 PM
Re: 10 Bolt Axles
The Warn kit is only available for 87 and prior 10 and 12 bolt axles.
[img]/wwwthreads_images/icons/wink.gif[/img]94 Yukon 350TBI 4L60E 6"ProComp 33-14.5-15 Swamper SSRs 15x10 Mickey Thompson Challengers Jacobs Ignition K&N Filtercharger 4.56:1 Ring and Pinion Superlift VSSB[img]/wwwthreads_images/icons/wink.gif[/img]
post #6 of (permalink) Old 10-02-2000, 08:46 PM
Re: 10 Bolt Axles
Does that apply to the 88 and later trucks and Blazers? I think the newer trucks have a different width axle, it may work in a 91 Jimmy, unless there was some internal change that I'm not aware of.
Shaggy is offline
post #7 of (permalink) Old 10-02-2000, 09:11 PM
Re: 10 Bolt Axles
Around 88 they changed from 28 spline to 30 spline axles, so the kit may not work for 88-91s. After 88 though, the 10 bolt was a mixture of 28 an 30 splines and the only way to tell if you have them is to tear the axle down and count them.
90K5
90K5 is offline
post #8 of (permalink) Old 10-02-2000, 09:22 PM
Re: 10 Bolt Axles
I got that info off of their(Warn) site - http://www.warn.com/Home/Products/Hu...s/FulFloat.htm. I checked into this sometime ago. Don't remember what the specifics are[img]/wwwthreads_images/icons/blush.gif[/img]. Maybe somebody else can chime in here.
[img]/wwwthreads_images/icons/wink.gif[/img]Somebody once said "Go Big" . . . Well we're goin' Full Size[img]/wwwthreads_images/icons/wink.gif[/img]
post #9 of (permalink) Old 10-03-2000, 11:25 AM
Re: 10 Bolt Axles
The Warn full-floating kits are available for the '88-'91 K-5's with 30 spline axles, but the f.f. kits are around $800. I would call ORD for more details.
I talked to several axle shops in the past about the c-clip eliminators used in race cars, and none of them recommended their use in off-road vehicles because of the side loading.
If you are just worried about the axle breaking and the tire coming off because of this, just spend about $300 and get some good strong aftermarkets shafts from a place like Moser. It seems like a lot of people think that the actual c-clip fails in one of these axles, but I've never actually seen this happen. The failures I have seen have always been the shaft itself breaking.
6.2Blazer
