My ZR2 to date
Here's a pic or 2, more are posted on the other forum here for S-trucks of the engine & stuff)when it was stock before the body lift. I'm trying to work out the details to do the suspension lift once and only once. Since the frame is wider and the suspension is different than a regular S-10 things aren't really available yet. I have an Airaid Tbody spacer, JBA nickle plated headers, K&N Gen II kit, MSD 6A, ASP power pulleys, Flexalite elec fan, 160* Tstat, and Hypertech tuning to date. I'm waiting on the Comp cams 1.6 roller rockers that are 2 be released at the end of next month, MSD 8.5 mm wires, a Granetelli MFS, and duals out the back with Supertraps to get the back pressure right for the V6(The blazer has a gas tank in the rear so I can run duals straight out without worrying about the tank on the side in the way). This Blazer runs like a fu****** bat outta H*** 2wd right now and will pick up more before I'm through. I get 19MPG and pull around 235HP. I hope to top out between 250-260HP when I'm through. I thought I'd do it right and get all the power stuff right before bolting on a lift and big tires and gears. This way I can enjoy the power and gas mileage instead of what other people do. They do the tires and lift and leave the engine stock with stock gears and it kills the truck till you upgrade the engine a lot even with a V8 and the gears. Hell, a stock 350 pulls less than 300HP and weighs more than my V6 too. If I can get 250-260HP I'll be happy on this short Blazer. I'm taking my time getting this all done right the first time. Alot of other people buy stuff, run for a year and upgrade. Then do it again. A waste of money and a collection of wheels, tires, and engine parts left over too. I'm going to run Weld XP truck wheels 10" and TSL SSR 35x12.50's. The combo is only 85lbs to pull, lighter than the stock wheels & tires, so I'll have an improvement there over stock. This Blazer WILL be a daily driver and somewhat of a mall cruiser, but I will be able to FLOG it in the bush when I feel like it. No rock crawling to beat it up, but mudding, fishing, and trailing. Thanks for all the replies from the full size guys!!!
