Re: NP241C Tranfer Case Actuator upgrade
I have done this swap, but don't remember exactly how it went. For the splicing, I followed the wires from the t-case that ran to the original actuator. If I remeber right, these are the only wires that you need to contend with. The new wire splices into the wire that is hot when the shift lever is in 4wd.
If this doesn't make sense, respond and I will look under my truck anb trace wire colors, etc.
It is much simpler than you are making it out to be.
Nich Kenny
'89 K1500 350/700r4
