Re: IFS upgrade
So the "heavy 3/4 ton" has 8 lugs? (so thats where these 14bolt, 8lug, SF rear ends are coming from, that makes sense now)
It sounds like the regular 3/4 ton is what they used to call a "heavy 1/2 ton", and the "heavy 3/4 ton" is what a 3/4 ton always was. (did that make sense[img]/wwwthreads_images/icons/crazy.gif[/img])
What you said makes sense, because my previous truck was a 6lug 3/4 ton, and when I lifted it the guy at Fly-N-Hi said that the 3/4 ton front end was basically the same as the 1/2 ton, and that the main difference between the two was the rear axle and suspension.
Is the 3/4 ton frame different from the 1/2 ton? (88 and up)
