Re: TH350, TH400, or TH700 - Which one\'s better?
The T400 is a 3speed auto, and is by far the strongest most dependable automatic tranny GM ever built! [img]/wwwthreads_images/icons/smile.gif[/img]
I would measure it, and see if it would be a direct swap for the T350, without re-cutting the driveshaft, if it will, I would use it. If it won't, then just rebuild the T350!
Forget about the 700[img]/wwwthreads_images/icons/frown.gif[/img]! to have a healthy 700 you have to spend well over $1000, and then since most people never use the OD, you end up with basically a T350 again!
