Re: Check engine light
Thanks Dave.
I ended up just just running that screw on TBI in a little to rev the motor slightly higher (didnt think there was an idle adj. so im not sure thats what it was, it basically pushed against the throttle arm) its basically compensating for the problem for now. but id like to figure out whats wrong with the thing. Its constantly stalling at idle while in gear and and if you give it to much gas it hesatates and takes a while to get up an go. I mested with the timing and it seemed to help, but the wierd thing is when I tried to time it, the mark on the balencer was at 10* when I started, now its running a little better and its off the scale, about at where 15-16 would be, on the before side. The sticker on the truck says its supposed to be at 0* . I didnt have a consistant check engine light before hand, but after I got out of the shop and home, it was on, and if im getting the code right, its a 21, (grounded WOT circuit or TPS circuit) I dont even know what a WOT is, and I have know idea what to do with a TPS. Any ideas? Im getting really frustrated.
Appreciate any help, thanks.
JAG
Las Vegas NV
<font color=red> 90 X-Cab Toyota V6 5Speed, 4 inch procomp, 3 inch DC, 35x 12.50 BFG Baja's.[img]/wwwthreads_images/icons/cool.gif[/img]
<font color=red> 87 K5 Blazer Silverado Bone stock. The womans ride.
