Re: Symptoms of cracked frame at steering box?
Take it over to the alignment shop- they'll be to tell if the frame is bent. The crack, if there is one, will be pretty obvious, you should see cracks without having to pull the box. If you're lucky, it's not cracked. I put ORD steering frame brace on my SWB, and have tweeked the hell out out of it for a couple years now, with no frame problems. If the frame is cracked at the box, you can weld some supports in, but it aint never the same. Those plates you weld in aren't very expensive.... Good luck dude...
<font color=blue>Maverick</font color=blue> [img]/wwwthreads_images/icons/smile.gif[/img]
