hello friends,
the autotrac transfercase nv246 in my 1998 suburban is destroyed. i am thinking of replacing it with a nv243 transfercase. the biggest advantage of this swap is the front drive shaft will stop turning at all the times. the front drive line will be engaged on when shifted to 4hi or4 lo.as i am putting on 6inch lift i am worried about front drive shaft vibrations. has any one done this swap before. i think it should bolt right up execept for the wiring part as this is shifted electonically. any help wouldbe greatly appriciated.thanks
if it comes stock in a GM vehicle 88-present, then it will bolt right in. as for the vibration, some folks find that with a 6" it does vibrate due to extreme angles. jesse at highangle driveline canmake stuff for you, or you canclock the front "axle" to make it work. most people have no trouble with a 6" though. good luck
just a thought to ponder - I've been shopping for a 95+ suburban, and happened to notice that the lift kits over 2" specify that they DONT work with the full time system....at a guess, I'd suspect that the shafts are CV's, or something, to prevent vibration from the full-time 4x4, and have shorter slip yokes. Shouldnt be an issue to swap in regular shafts, but if $$$ is tight, definitely something to look at before you start parts swapping.
(*** also might be worth looking to see if the full time case uses U-joint collars, or flanges to connect the shafts to the case))
the swap can be done. i've never done it because my truck has the part time case stock.
you are going to need to cut a hole in the floor for your lever. from what i have read about the auto track case it is junk. and most lifts require a new drive shaft with the auto track case. i would try and get the driveshaft, linkage, lever, thing that the lever goes into, and case all from the same truck. that way you have all the pieces you need.
that has some answers. if you have not already read it.
best of luck.
Related Threads
Off Roading Forums
1.4M posts
22.4K members
Since 1999
