Fluid Change - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-10-2005, 07:49 PM Thread Starter
Fluid Change
I changed the rear diff fluid last week. This stuff was completely black. I am going to get the front done this week as well. My question is, should I also get the transfer case done and should I also get the transmission done as well. i hear getting the transmission done at this point is worthless especially since I have 73,xxx miles on the tahoe. What are your opinions?
Yukon97 is offline
post #2 of (permalink) Old 07-10-2005, 09:43 PM
Re: Fluid Change
yes, if the trans has no shifting problems than it better to do it now than waiting till its to late. I always tell people to change trans fluid every 30,000 miles.
post #3 of (permalink) Old 07-10-2005, 11:14 PM
Re: Fluid Change
id definatly change the trans, and get it flushed if you have axcess to the stuff to do it. with an auto tranny i wouldnt think it would be worthless to change the oil twice a year. regardless of miles put on it. the oil is subject to such high heat at exstended periods that youd only be doing yourself a favour by changeing it.
id also consider a ribbed tranny pan that adds 2-4 quarts of oil to the system, then be running between 7-9 quarts of oil through the tranny instead of 5 or so.
changeing everything liquid every so often is always a good think. do it all now. not when something goes wrong.
alittle preventive maintence goes along ways
Evan
The_Kid is offline
post #4 of (permalink) Old 07-11-2005, 11:38 AM
Re: Fluid Change
Last summer I had to replace my transmission. Now I have decided to change the fluid every year. Last week I changed to fluid in both diffs, tranny, and engine oil. The front diff is easier than the rear. I wouldn't take it to get done. There is a fill and drain plug. Get a nozzle pump thing from the autoparts store and pump in a few quarts. I bought a gallon of the Lucas Oil stuff. I put a quart in the engine, diffs, and tranny. I can totally tell the difference in the shifting. I used B&M ATF and it made the shifting feel crisper. The only bummer is that the fluid is blue and hard to see on the dip stick.
4x4mike is offline
post #5 of (permalink) Old 07-12-2005, 07:43 PM
CodyZ71's Avatar
Re: Fluid Change
Whoever told you its worthless to do is a freaking idiot.
I did mine awhile back, pretty dirty it had 30,000 on it.
But I noticed it shifted better afterwards.
Maybe put some seafoam tranny cleaner in there before?
And ya do it yourself unless ya like wasting money.
CodyZ71 is offline
post #6 of (permalink) Old 07-12-2005, 08:14 PM Thread Starter
Re: Fluid Change
Reason being is that some transmissions adapt to the metal fixings in the casing. I have changed both the front and rear diff along with the transfer case. The transmission is the only thing left. I won't do that in my driveway. I will be paying someone to do that. Should i get the flush or the whole maintenance done to it?
Yukon97 is offline
post #7 of (permalink) Old 07-13-2005, 10:43 PM
Re: Fluid Change
I would have the flush done. Last year I did a filter and fluid change. 2 months later the tranny blew up, driving in a matter that I had been doing for 60K miles. Now with the new transmission I will change it once a year.
4x4mike is offline
post #8 of (permalink) Old 08-20-2005, 10:38 PM
Re: Fluid Change
That rear fluid being black might be because of the clutches being worn....check them if you have a posi. or locking type differential.
zdpzimmer68 is offline
post #9 of (permalink) Old 08-21-2005, 09:39 PM
Journeyman
Griasev's Avatar
Re: Fluid Change
Your tranny should hold more fluid than just 4-5 quarts. When i replaced mine, it took, about 12 quarts to fill tranny and torque converter. They do hold a fair amount of fluid in them. Also i would suggest putting a tranny cooler on it and ditch the factory radiator cooler. Even if you don't tow, or wheel alot, it will keep it cooler, and make it last longer.
Griasev is offline
post #10 of (permalink) Old 08-22-2005, 11:02 PM
Re: Fluid Change
to make the fluid change easier. buy a drain plug for the trans pan. with the pan on the tranny get drill and the an apropriat size drill bit for the pan.
then just drill a hole in umm id go the back section and let it drain. then unbolt the pan bolt the drain plug in change the filter and fill it full of fluid. this will make every fluid and filter change from now on alot less messy and save you time under the truck.
The_Kid is offline
