How many miles is too many on 14 bolt - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 07-05-2005, 11:40 AM Thread Starter
How many miles would you consider to many on a 14-bolt sf axle. I have found some 14-bolt SF axles but they are from 88 work trucks with some up to 200,000 miles. I found one our of a 88 C2500 it says 4x4 with 194,000 for $600. This is with 4.10 gears. If i find one with 4.10 gears would i be ok with them instead of 4.56. Then i would only have to swap the front gears out and save some cash...
I haven't had a chance to run over and take a look at it yet. been to busy here at the shop to get away.
Big_Red is offline
post #2 of (permalink) Old 07-05-2005, 03:03 PM
Re: How many miles is too many on 14 bolt
200,000 on a gear set is a lot. I would think that as long as the housing is straight and that the axles have good bearing surfaces it should be good. I have no idea how many miles is on mine. I replaced all the bearings, threw out the differential, and replaced all the brake components (quite cheap for all brake stuff). Take a look at where the axle tube goes ito the center section and at the flange at the brakes.
4x4mike is offline
post #3 of (permalink) Old 07-05-2005, 08:16 PM
My 8 lug 14-sf has about 450,000 on it now. I don't recall the bearings ever being done, but they might've. My pinion bearings are loosening up some now, I need to have them done.
post #4 of (permalink) Old 07-07-2005, 10:40 PM
lol i was gona thro 400 out there. the 14sf in my blue and silver 89 had ticked over 200k 4 years ago. in all reality is got mayube 350 on it.
factory original ring and pinion and all bearings. pinion bearins are sloppy as all get out, ring teeth are pitted, and chipped. she howls alittle.
its seen alot of miles off road. and man it just wont puke. ive got bearings and seals, now i need to round up a detriot, and possibly discs.
even as we speak the axles under the truck and has been the truck im useing as my daily driver. if the ring and pinion teeth looked better id toss new bearings in it and roll. but i need gears anyways and they realy are lookin fairly sad.
The_Kid is offline
post #5 of (permalink) Old 07-07-2005, 11:40 PM
Mmmm detroit and disks for a 14sf :drool: don't tease me Evan... I thought I had a detroit for a 14-ff last year in the paper for like $50, but it was for an old Eaton axle as it had 1.5" axles but like only 29 splines.
post #6 of (permalink) Old 07-09-2005, 10:59 AM
thats the plan. cant find the dang sf disc conversion stuff though. it was pretty much the same setup as the ff. alittle more spendy but a good kit. still had to come up with rotors and cals. but thats easy.
The_Kid is offline
post #7 of (permalink) Old 07-09-2005, 12:41 PM
http://www.tsmmfg.com/2631.htm
http://www.blackbirdscustomtrucks.co...x7.html#3fbolt
That's the two I've found. I've heard SSBC might have a kit, but I can't find it.
post #8 of (permalink) Old 07-09-2005, 06:24 PM
both 8 lug kits. wonder if front 6 lug rotors will work.
i always thought the first kit was a 6 lug kit, this is the first time i noticed that it comes with 16 wheel studs.
dont know how much it matters either way around, dont know how if any difrent the 8 lug semi axle is compared to the 8 lug version.
The_Kid is offline
post #9 of (permalink) Old 07-11-2005, 10:42 AM
I have checked into it before and they will do 6 lug for you. I decided against discs because of the price.
4x4mike is offline
post #10 of (permalink) Old 07-11-2005, 06:22 PM
its less than 400. isnt bad anyway you cut it, unles you mill all your own brackets and what not. pretty sure you can find some calibers for free or very cheap.
i remember way back when you couldnt touch disc conversion for less than 800. kinda crazy.
The_Kid is offline
