Posi-Lock Questions - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-24-2005, 09:40 AM Thread Starter
Posi-Lock Questions
I think my thermal actuator may have gone out on my 90 Chevy 1/2 ton 4x4. I'm debating on replacing the thermal unit, if it is bad, with the after market cable controled system. I believe it is called posi-lock. My only concern if that I live in MidMichigan and I'm wondering if the snow, ice and freezing rain in winter would have a negative effect on the unit. If ice forms up there or frozen mud will it disable the unit? Any body from the cold country area that has one could you please advise me if this is a good unit, or should I stick with the thermal unit or look for something else? If I should look for something else is there anything else that you have used that works in these conditions.
Thanks..
Bill
wsmm is offline
post #2 of (permalink) Old 03-24-2005, 10:50 AM
Re: Posi-Lock Questions
Well.....look at it this way.....the original one (I assume it was anyway) lasted 15 years.....is that really so bad? Why not replace with the same unit and hopefully it will last another 15, not bad if you ask me.
Beats monkeying with a manual cable type....personally I wouldn't do the cable for that reason and the reasons you mentioned.
I know I have had e-brake cables freeze up on me before....
Cosmo is offline
post #3 of (permalink) Old 03-24-2005, 04:49 PM
Or... for the best of both worlds upgrade to the servo motor style that came on the 97's or so and newer. If you go to a Chevy dealer and ask for the stock actuator they will tell you its no longer in production. For about 150 bucks they will sell you a special wiring harness that you wire into the t-case select switch, and the new electric motor style actuator. It makes 4x4 kick in instantly and its also very reliable. I did this to my 1993 K1500 and it was one of the best upgrades I ever did to it. Its costly, but then so is a posi-lock cable actuator. [img]images/graemlins/wink.gif[/img]
Krayzie is offline
post #4 of (permalink) Old 03-25-2005, 02:47 AM
MSF
MSF's Avatar
I live in Illinois & I have had pretty good luck with my posi-lok. The trick to it is getting the cable housing to stay in place so the cable travels through it smoothly. I would say either get a posi-lok or get the 97+ electric actuator. Both would work well, but the posi-lok gives you 2-wheel Lo capability, and peace of mind that YOU control when the front axle engages. I like that about it.
MSF is offline
post #5 of (permalink) Old 03-27-2005, 01:36 PM
Journeyman
Griasev's Avatar
I did the same thing Krayzie did with the electric actautor, works wonderfully. The only problem I had was running a pair of 150 watt KC Daylighters, and my actuator on a single battery. It just didn't want to stay engaged, but dual batteries fixed that little problem.
Griasev is offline
post #6 of (permalink) Old 04-06-2005, 11:17 PM
i ran with the posi-lok in my z-71 for 2 years in michigan and didnt have any problems. i just dont like the idea opf electrical nonsense altogether much less on the axle where its wet and muddy.
u4ia4 is offline
