Re: Static Hissing Noise
All those filters are for the most part are capacitors in the micro farad range in a pretty shell and wires.
For CB's, it won't necessarily stop the noise but it will filter some of it out. Same with the radio.
Aside from checking all of the above, make sure to check your spark plugs and spark plug wires to make sure they meet specs for filtering out noise. I can't remember if the resistant or non-resitant plugs are the key, or if the plug wires are that way, but it does help. And if there's a break in one of the wires that could do it as well...
HTH
