Journeyman
Re: oil filter adapter leak
I'm assuming you mean the quick connect lines? Find out which one it is, then go down to the dealer [yes it is a dealer only part]. Get the correct screw in piece that goes into the oil filter housing, then buy a new plastic 'clamp' for lack of better wording. Grab a pair of channel locks, grip both tabs of the one currently on, then pull back at the same time. Yes it is a bit of a bitch and may take a couple of tries, but it does work. the screw in connector is about $12 or so, and the 'clamp' is around $2-$3 [mind you prices may vary from dealer to dealer]. It should only take you no more than 30 min. I did mine in about 20 min. in 14" of snow a couple of months ago.
