Wierd cut-out under load - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-22-2004, 03:28 PM Thread Starter
Shorts's Avatar
The truck does this really bad cut-out....I almost hear a metal on metal sound....even kinda like a misfire... This happens during acceleration, or if I'm on the hwy, let up the gas, then step on it again. It is not consistent. Usually when the truck is under load and is suppose to accelerate but can't...before the tranny downshifts. I hear this aweful clank/clunk/jam around the mid-to-frontpsider of the truck.
Hmm, rereading that, I didn't exaplain that so well, but even if you remotely think you understand what I said, chime in. I'm thinking either the tranny/TC, fuel pump, or have some freaky misfire thing going on in the ignition somewhere. No, there are no codes.
Shorts is offline
post #2 of (permalink) Old 03-22-2004, 03:32 PM
Re: Wierd cut-out under load
i think timing/ignition stuff. T-case stuff is usually reproducable in all gears. how hot is it down there? hows our timing? thinking perhaps engine knock [img]images/graemlins/thud.gif[/img]
u4ia4 is offline
post #3 of (permalink) Old 03-22-2004, 10:58 PM
Sounds like mine did when my cat started to go bad. Would only make the sound under load, sounded like someone was hitting the bottom of the truck with a sledge hammer, and took about 2 weeks before it started throwing codes. Drove me crazy, could not reproduce it in the shop. Pulled half the truck apart trying to find it before it threw a code. Replaced the cat and its been OK since.
BigDuckie is offline
post #4 of (permalink) Old 03-22-2004, 11:06 PM
Carpal \'Tunnel
wrath's Avatar
I'd start with the EGR system. After that, I'd head towards ignition system. Usually when MAP sensors start to go they throw a code right away and at idle the motor changes RPM all the time.
wrath is offline
post #5 of (permalink) Old 03-25-2004, 03:43 PM Thread Starter
Shorts's Avatar
i noticed my tach needle gets a little twitchy sometimes...usually when accelerating. what does that mean?
Shorts is offline
post #6 of (permalink) Old 03-25-2004, 05:32 PM
a little twitchy....mine jumps from nothing to eight or so until i read about 8 miles per hour then is smoothes out.
u4ia4 is offline
post #7 of (permalink) Old 03-25-2004, 05:36 PM
Carpal \'Tunnel
wrath's Avatar
Could mean a bunch of stuff. I'd start with making sure the lead at the ignition coil is on there well. I'd pull it off, bend the terminal in the connector, and put it back in. If it's still there then it's probably something else.
wrath is offline
post #8 of (permalink) Old 03-25-2004, 08:23 PM
Mine was doing the exact same thing, mainly making the noise when under load at low RPM's. A shop said it was pinging, and to run the gas tank almost empty and fill it with the best gas i could find. If it doesn't make the noise after that, you know you have a pinging problem. I got my timing set back 4 degrees, and it solved the problem. Now i can run the cheapest gas on earth and it doesn't ping [img]images/graemlins/smirk.gif[/img]
dhcomp is offline
