New Breakage? - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-18-2004, 03:00 PM
HOEBOGGER
New Breakage?
[img]images/graemlins/confused.gif[/img]Me again. I got stuck in a mudhole last night up to my doors. Some thick soup. Long story short, I got out without a tow it just took an hour and a half. But I thought I was home free until I got to the car wash and noticed a horrible "clank" sound when reverse or drive was engaged. It drives fine though. Nothing out of the ordinary. Could this be my trans.? If not, what else? Is it safe to drive until I can fix it? Thanks for the help. [img]images/graemlins/confused.gif[/img]
post #2 of (permalink) Old 03-18-2004, 03:40 PM
Re: New Breakage?
Sadly it could be many things. First, I would check the u joints on your driveshaft. Then check for water in the tranny, differentials, xfer case. By the way you're describing the issue, I would guess it's a ujoint going or gone.
Good luck with the vehicle. I hope you at least had fun while you were out there. I know it's not fun getting stuck, but getting there really is.
blabhern is offline
post #3 of (permalink) Old 03-18-2004, 05:04 PM
Re: New Breakage?
change your driveline fluids immediately. your vent tubes are lower than the doors and you likely have water i nthe fluids.
BTW you described the noise when you engage a gear, it is likely the u-joints. check them first as they are cheap and easy to repalce
u4ia4 is offline
post #4 of (permalink) Old 03-18-2004, 10:34 PM
Re: New Breakage?
What they said.
About being stuck for 1 1/2 hours.....thats nothing Me and my cousin were stuck for 7 hours one night. We went out to a mud hole about 8:30 at night and didnt get home till 3 in the morning. [img]images/graemlins/cussing.gif[/img]
post #5 of (permalink) Old 03-19-2004, 01:30 PM
HOEBOGGER
Re: New Breakage?
May sound like a dumb ? but how can I tell if it's "going"(u-joint)? At first glance, everything looks fine. I am currently operating with a broken arm, so I can't really dig in to anything very extensive.
post #6 of (permalink) Old 03-19-2004, 02:56 PM
Re: New Breakage?
well you and your gimp arm are gonna havea hard time testing it depending on the cast you have.
U-joints connect the driveshaft ends to the shaft. they are supposed to be very tight tolleranced. as in they shouldn't be able to wiggle. if you grab the driveshaft and the "other end" and try to twist them back and forth, it shouldnt have any play...or VERY VERY little play. most commonly the rear u-joint fails due to its being exposed to water more often, and becasue of the way the axle behaves under load (axle wrap) but thats a whole different thing there. basically check the u-joints for wiggling
u4ia4 is offline
