Well, I bought it. - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-12-2004, 10:13 AM Thread Starter
Well, I bought it.
Here is the new axle. It has 14 bolts but the diff housing isn't the same as others I have seem. MAybe this is the way the SF housing looks.
4x4mike is offline
post #2 of (permalink) Old 03-12-2004, 10:15 AM Thread Starter
Re: Well, I bought it.
There is some wear on the spider gears. I am going to put a Detriot in there. Will that replace the spider gears. Also, is this an open carrier? If so the Detriot is a drop in right? Will I need to adjust backlash, etc?
4x4mike is offline
post #3 of (permalink) Old 03-12-2004, 10:17 AM Thread Starter
The axle tube is narrower than my ten bolt. The spring pads center to center are the same though. I figured that because of the wider brakes the wheels will stick out the same, right? I have not been able to get a measurement.
4x4mike is offline
post #4 of (permalink) Old 03-12-2004, 10:18 AM Thread Starter
Is this bad? These marks from the pinion? Will this part be replaced my the locker?
4x4mike is offline
post #5 of (permalink) Old 03-12-2004, 10:41 AM
A1980GMC's Avatar
That looks like a 14 SF to me. Is it 8 or 6 lug? How did you get it for?
Laters, Ryan
A1980GMC is offline
post #6 of (permalink) Old 03-12-2004, 11:11 AM
Dude, that thing is WASTED. Look at the pits in the gears, and I think you will be lucky if the pinion housing isn't thrashed from it rubbing on the carrier... You need to get a different one if thats an option... too much garbage on the inside. Just my honest opinion... wait for something with a lot less wear to come along.
Krayzie is offline
post #7 of (permalink) Old 03-12-2004, 11:28 AM Thread Starter
I want to put a detroit in there. Won't it replace those gears. I when you say gears, are you talking about the spider gears. How much would they be to replace? What do think about the width?
4x4mike is offline
post #8 of (permalink) Old 03-12-2004, 11:35 AM
On the width measure the wheel mount surface to wheel mount surface distance and compare with your 10 bolt.
On the inside that things pretty wasted... The detroit will be a whole new carrier, not a drop in like the 14 bolt full floater uses.
You will have to set up the gears again, check backlash, set carrier bearing preload, run a pattern, etc. And by the looks of the marks on the carrier the pinion depth is way to deep if it's hitting the carrier. Whoever set the gears up had no idea what they were doing OR the pinion bearings are shot and allowed the pinion to move back OR the pinion nut backed off somehow and allowed the thing to drop in. With it being that deep I can almost guarantee that the gears are toast and you will need a new set.
Got any pics of the ring/pinion? If the spiders are that wasted the ring/pinion can't be too far behind...
Best Auto Insurance | Auto Protection Today | FREE Trade-In Quote
willyswanter is offline
post #9 of (permalink) Old 03-12-2004, 11:41 AM Thread Starter
I want to do a complete build up on this thing. Before I tear it apart I want to make sure that I have the right axle. Willys, you say that with the Detriot I will need a new carrier? If this is the case then it is not a big deal that the one in there is wasted, right? I haven't taken out the ring or pinion but they do not have any wear like the spider gears. They are 3.73 and look really good.
4x4mike is offline
post #10 of (permalink) Old 03-12-2004, 12:00 PM
You won't need a new carrier, the detroit is the carrier, it completely replaces the carrier and the ring gear bolts to it.
