ball joint ?'s - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-24-2004, 11:04 PM
bggrnchvy
ball joint ?\'s
What is the typical lifespan of a ball joint on a 8.25" ifs frontend? I ask becuase my front end is aligned within spec and i still get a strong pull, funny wear pattern and when i hit the brakes it pulls harder left than just running down the road. Any suggestions?
post #2 of (permalink) Old 02-24-2004, 11:58 PM
Re: ball joint ?\'s
Not sure on life, but have u tried balancing/rotating your tires? Your ball joint guess it probably a good one, but if they are really shot most places won't align it at all.
dhcomp is offline
post #3 of (permalink) Old 02-25-2004, 12:40 AM
MSF
MSF's Avatar
Re: ball joint ?\'s
Big tires do require frequent rotation. I rotate every 3000 and they have always worn even (and that's with Thornbirds!). But definitely check for loose tie rod ends, pitman arm, idler arm, and ball joints.
MSF is offline
post #4 of (permalink) Old 02-25-2004, 08:07 AM
Re: ball joint ?\'s
Could also be a sticky brake caliper. I had that on a Grand Am the wife drives. Took a while to figure it out. Had to check everything else first.
blabhern is offline
post #5 of (permalink) Old 02-25-2004, 02:35 PM
bggrnchvy
Re: ball joint ?\'s
The truck has 141,000 miles so i figure they are probably worn out. Time to replace them, yea all 4. I already had to replace the upper a-arm bushings. Any special tools required to replace them? And who makes a good long lasting ball joint?
post #6 of (permalink) Old 02-25-2004, 04:04 PM
Shorts's Avatar
Re: ball joint ?\'s
MOOG
Shorts is offline
post #7 of (permalink) Old 02-25-2004, 11:29 PM
bggrnchvy
Re: ball joint ?\'s
Should i rent the ball join puller from autozone? How difficult is the entire process? How long should i alot for it? And is about $100 for all 4 joints a good price? Can someone give me some good do's and don'ts from thier install?
post #8 of (permalink) Old 02-26-2004, 06:56 AM
Shorts's Avatar
Re: ball joint ?\'s
wow, 4 MOOG BJs for $100 - i wanna shop where you do. those things run 32 and 34 each....about $140 total.
i dont know if you need a press, look and see if the LCAs are pressed in or bolted in.
UCAs - grind off the head and punch the rivet out
LCAs - same idea, but huge PITA on the rivets
Shorts is offline
post #9 of (permalink) Old 02-26-2004, 07:58 AM
Re: ball joint ?\'s
I second shorts comments. I just did my balljoints a couple of months ago. Once the rivets are out, its a piece of cake. Get the puller from autozone to make it easier.
Enjoy. Hope that cures your issue
blabhern is offline
