- GM Standard IFS Trucks & SUV's
(https://forums.off-road.com/gm-standard-ifs-trucks-suvs/)
- - Speedometer
(https://forums.off-road.com/gm-standard-ifs-trucks-suvs/185479-speedometer.html)
Speedometer
Simple question:
When bigger tires or a lift kit is put on a vehicle, it throws the speedometer off. How is this corrected? |
Re: Speedometer
you gotta adjust the vehicle speed sensor reading. get a TruSpeed.
Re: Speedometer
another option is to crunch the number and figure out the appropriate gear ratio and re-gear. the simplest and cheapest method is the truspeed way.
i have 35s and re-geard so the speedo is off by less than one percent, but i run 31s in the winter so the spedo is off by about 13%. i just drew dashes on my speedo at 35, 55, and 70MPH just to give me an idea in the winter. |
Re: Speedometer
New tire size / old tire size x the speed your speedometer says = actual speed.
That's how I figure mine. I just do the math while I drive, 90% efficient, so 30 is 27, 50 is 45, and so and and so forth. Of course you have to factor in gear changes too. And yes, it would be much easier to get a truspeed, but that costs money. [img]images/graemlins/smile.gif[/img] |
Re: Speedometer
Last time I posed this question to a dealer they said that you could have the speedo recalibrated. When I said "Great! When can I come in?", they said "Oh, we don't do that here; you can take it to a speedo shop to have it done".
I never bothered, since the only calibrating shop I knew in the area was sort of shady and/or already out of business... |
Re: Speedometer
Hello Folks,
Over at Randy's Ring & Pinion website has a bunch of equations to figure the ratio's out. And etc... http://www.ring-pinion.com/calculato...latorsind.html |
Re: Speedometer
www.4lo.com has some good calculatorsa as well
User Alert System provided by
Advanced User Tagging (Pro) -
vBSecurity v2.2.2 (Pro) -
