Brake switch replacement - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 01-09-2004, 11:47 AM Thread Starter
Can anyone tell me how in the world to you replace the brake switch in a 95 HOE. I have found the box (thanks to previous post) and was able to get my hand on it and get teh rear clip off. There is a another clip that I cannot get off that the switch seems to rotate on. How do I get that clip off with out cutting my hands anymore than they are???
SERVORD
Servord is offline
post #2 of (permalink) Old 01-09-2004, 12:23 PM
Shorts's Avatar
Re: Brake switch replacement
eeeek...that thing is hazardous to change out. its been a while since i replaced mine, all i recall is the one clip on there....but like i said, its been a couple years since i've looked at that. sorry i couldnt help ya much [img]images/graemlins/crazy.gif[/img]
Shorts is offline
post #3 of (permalink) Old 01-09-2004, 01:24 PM Thread Starter
You are exactly right. There is one clip and it is a PITA to get off. Do you remember how you got it off??
Servord is offline
post #4 of (permalink) Old 01-09-2004, 08:41 PM
i did it on mine when i first bought it from sparty. the brake lights didnt work and the fuse was fine (turned out to be a different fuse) so i replaced the brake switch. that little clip came off easily enough with a leatheran. i forget which tool i used though, prolly the very slender "screwdriver" that looks more like a punch.
getting it back on is the challenging part. you have to lift the tab up before it'll slide on. i used a loop of string to accomplish this. i have to get going cuz the g/f made dinner and i"ll be on the [bleep] list if I'm late, but, i can check tomorrow and look at it up close and see if ican remember what i did.
u4ia4 is offline
post #5 of (permalink) Old 01-10-2004, 07:04 PM Thread Starter
I got it done. After cutting my right hand up (chevy really needs to use blunted scrwes) I got the swtich replaced. The lights and ABS are working perfectly now. Thanks for the replies.
SERVORD
Servord is offline
post #6 of (permalink) Old 01-12-2004, 11:26 AM
My brkae lights stay on all the time. To turn them off I have to pull up on the pedal. Is the problem the brake switch? I'm not sure where it is but know that I want to replace it because it is driving me nuts.
4x4mike is offline
post #7 of (permalink) Old 01-13-2004, 07:23 AM Thread Starter
I am not sure how that works out for you but I can tell you that after replacing the switch if you breath too hard on the brake pedal the lights will come on. I am not sure if that is the way is should be. The switch has two attachments to the brake pedal. The part of the switch that is closest to the driver has a hole, that a pin attached to something under there, goes through. Then you have to place a clip on the end of the pin after you have the switch on there. There is a also a small clip that goes over the brake pedal. This clip is a pressure fit and I found it really easy to slide the clip off of the pedal. That may be your problem, in that, the clip may have just worked its way loose. When you check it out make sure to have some bandages handy. You may be needing one as there are a few pointed screws under there.
SERVORD
Servord is offline
