Front differential problems - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 12-02-2003, 08:45 AM
Blk88GT
So I went around a corner yesterday morning and heard some noises. I turned down the radio and the heater (it's cold up here in Canada!) and tried another corner. Sure enough, the passenger side outer CV joint let go.
So I pick up a ton of parts and head home. I figured if I'm going to take it apart, I might as well do the whole front end. New upper/lower balljoints, tie rod ends, sway bar endlinks, idler arm, etc.
I put it all together and then noticed something. The passenger side axle slides in/outa solid 3/4"-1"
This is NOT good.
I'm being told there is a clip that holds the axle in, with a gear on the end of it and I have to remove the axle tube from the housing by the 5 bolts around the 4x4 actuator solenoid. Is this correct? It looks like I have to drop the differential down to get at the top bolts.
Any help would be appreciated, it sucks having to get a ride to work from your parents who live 35 miles away.
post #2 of (permalink) Old 12-02-2003, 11:17 AM
Shorts's Avatar
Re: Front differential problems
it doesn't take long to drop the diff, just make sure you have a floor jack under it to roll it in and out from under there. airtools will be nice to, especially reaching up there to get to the top mounting bolt, but you'll be ok without them. you can pull that axle tube off by removing those 5 bolts. i had to do that to check the stupid gear thing in there when my front end got locked. to tell you the truth, i don't even remember looking at the end of the axle shaft and how it was connected in there. so i can't help ya much. oh yeah, maje sure you have some sealant when you put the axle tube back on the diff and tighten the 5 bolts.
Shorts is offline
post #3 of (permalink) Old 12-02-2003, 12:33 PM
Blk88GT
Awesome, thanks so much. Do I have to drop the CV shaft on the drivers side, or can I just let it hang down?
What a disaster this is.
post #4 of (permalink) Old 12-02-2003, 05:18 PM
Shorts's Avatar
yeah, undo the 6 flange to CV joint bolts on each side. then move them ouy of the way when you drop the diff. use bailing wire or something to hold the cvs up.
Shorts is offline
