Re: actuator wiring for 94\' k3500
ok, it's done!!!!! finally
what a pain in the butt, not the actuator, but the BROWN wire. i could not get that wire up there through the floor for some reason, probably because mine has got this metal encasement around the shifter and allthe heat sheilds, but i did manage to rig it up for the winter. i traced that BROWN wire from the loom at the shifter to the box near my fuse box, and spliced it into there, then through the fire wall and back over to the pass. side where the BROWN wire at the the new harness was. works like a charm.and just in time too as we are in the process of getting some serious snow up here in ct. thanks for the help
