Re: Alternator Upgrade
Hold the phone.. There was no 85 amp option in a 1994 K truck. The options are 100, 105, and 124 amp. If you have an 85, then it does not belong in there. Post your VIN number and when I go into work tomorrow (Friday) I will let you know what you have in yours. If you have a 100, you can go to a 105. Or vice versa. The 124 has a much larger case, and is held on by bolts opposite of each other. You would need a completely different bracket to hold it on... If you need a bigger alt. go aftermarket. Its the only way to get a GOOD increase in amps.
Mike
