Re: Torsion Bar Q\'s??????
First untension them. I used a large c-clamp with the swivel pad knocked off. Insert that into the dimple on the bottom of the torsion bar key and then crank it up enough so that once you remove the torsion bar bolt you can slide the pc out that the bolt goes into. Make sure to index mark everything before you take it off. Mark or count number of threads on the bolt before you remove it and I also mark a dash on the torsion bar to the crossmember and lower arm for later reinstallation. Once the bars are untensioned, take a 2x4 as Shorts mentioned and bang the crossmember towards the rear...that is after unbolting the crossmember. There are a couple pics of doing the torsion bars when I put my lift on, they are on my webshots page
