Re: Ever worked on IFS
<font face="Comic Sans MS">I sure hope you're installing lower ball joints at the same time... It'll save you much time and heartache down the road when you realize you should have done that... One of those deals while you've got it apart it's relatively cheap insurance against having to do it again anytime soon...
I assume the ball joints are factory originals and riveted in... Just drill out the heads and chisel them off, they'll come right off... Make sure obviously you've relieved the suspension by putting a floor jack under lower A arm and raising jack platform to level the assembly, and then lower the jack after you've popped the ball joint... Otherwise it can slam down and possibly cause injury... New ball joints should have bolts you use instead of the idiotic factory rivets... Simply use a "pickle fork" and plenty of arm power to seperate the balljoints from the spindle... GM has a special tool you can use but I tried one before and it didn't work worth a hoot for me... Obviously I imagine I merely had a stroke of bad luck with their tool as I'd hope their tool would work, but if you're replacing the little dust boots on the balljoints, you may as well smack 'em outta there with brute force...
I would put a new pitman arm on as well, since they used a stupid design on the IFS trucks, and the pitman arm is not just a piece of steel like the SFA trucks were, the joint is a permanent part of the IFS pitman arm... What a major PITA...
As for the wheel bearings, they are sealed and non-servicable, if they're bad you have to shell out the cash for new ones... I have never seen a rebuild kit for these sold anywhere... I suppose if you're feeling parfticularly ambitious you could go to a bearing supplier, give them the bearings that are inside, ask them for that, and a seal that'd fit and hope you can get it back together... Last time I priced one of these it was in the $100 range, however, your mileage may vary...
While you have your spindles out make sure to double check all the boots on your CV's and ensure they are in good condition... Removal requires removal of the spindle again, at least popping 1 joint out of it... Just much better to double check every single thing in there to help avoid essentially doing the job again, or doing most of the steps leading up to that particular job...
Good luck, and keep us posted...</font>
