Subject: Aircraft Maintenance
Aircraft Maintenance Problems and Solutions: Never let it be said that ground crews and engineers lack a sense of humor. Here are some actual logged maintenance complaints and problems, known as "squawks," submitted by QANTAS pilots and the solution recorded by maintenance engineers. By the way, Qantas is the only major airline that has never had a fatal accident.
P [in list below means] - The problem logged by the pilot.
S [in the list below means] - The solution and action taken by the engineers.
P: Left inside main tire almost needs replacement.
S: Almost replaced left inside main tire.
P: Test flight OK, except autoland very rough.
S: Autoland not installed on this aircraft.
P: No. 2 propeller seeping prop fluid.
S: No. 2 propeller seepage normal. Nos. 1, 3 and 4 propellers lack normal seepage.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S: Live bugs on backorder.
P: Autopilot in altitude-hold mode produces a 200-fpm descent.
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick
S: That's what they're there for!
P: IFF inoperative.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windscreen.
S: Suspect you're right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search.
P: Aircraft handles funny.
S: Aircraft warned to straighten up, fly right, and be serious.
P: Target radar hums.
S: Reprogrammed target radar with words.
P: Mouse in cockpit.
S: Cat installed.
My pops sent this to me earlier in the day as i am going to be an engineer. i figured ya'll might like it with your crazy drug smuggling airline or whatever you're gonna be doing with the Hercs. if you need a smartass engineer let me know.
---Peacock posted this
<font color=red>'96, richmond 3.73, detroit rear, cold air, dual flowmasters, new drive-train,</font color=red>
