Medium fan speed not working - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 02-21-2002, 12:13 AM
A friend of mine has a 86 3/4 ton GMC and the medium fan speed has stopped working. The high and low works find so I think the motor is still fine, but i'm not sure what it is. Any ideas. Thanks.
Tim Springer
1980 CJ7
1998 Chevy K1500
<font color=green>WALSTIB</font color=green>[img]/wwwthreads_images/icons/wink.gif[/img]
post #2 of (permalink) Old 02-21-2002, 12:51 AM
Re: Medium fan speed not working
well my first hunch would be the switch. I"m not sure how its set up on the older rigs, but tear it apart and see. prolly just a bad contact
---Peacock posted this
<font color=red>'96, richmond 3.73, detroit rear, cold air, dual flowmasters, new drive-train,</font color=red>
u4ia4 is offline
post #3 of (permalink) Old 02-21-2002, 01:01 AM
TxFireman's Avatar
I'm really searching here but my memory is scetchy. I think there is a plug on the firewall that has 3 to 4 prongs coming out of it...well if you unplug it at least. Anyway, mine had that deal where it is always running on low for circulation or whatever, and I took the low speed one (prong) and bent it down and plugged it back in so I didn't have to have it blowing all the time. It could be that his came loose and that is causing it....Or that a connection on the back of the switch came loose.
TxFireman is offline
post #4 of (permalink) Old 02-21-2002, 01:59 PM
i had the same problem with Honda Accord I once had. (It was a quick car phase I went in) Anyway..... it was a resistor that went in the resistor pack. I replaced that and whalla... all fans working. Not sure exectly how the GM's do it but I'd check there. Do a check with a continuity tester to see if its open.
Due to the current economic situation, the light at the end of the
tunnel will be turned off until further notice.
post #5 of (permalink) Old 02-21-2002, 06:23 PM
Carpal \'Tunnel
wrath's Avatar
On the air intake system somewhere around the fan is a plug with three or four contacts. Pull it off and clean it out and stick it back on.
If he's got air conditioning, it'll be on the air conditioning tower just left of the canister.
Since it's not that only high works, then it's not the coils. The way the system works is that on low it goes through all the coils, medium it goes through one less coil, and high it goes through one coil or no coils.
"The difference between a yooper and a lowper is that a yooper oil change involves just changing the filter whereas a lowper oil change involves just changing the oil."
wrath is offline
