Re: driveshaft length??
I would think it would probably be accurate (you could always check with a drive shaft shop to see what they think). Did you notice any of the normal discoloration marks on the slip yoke at the end of the drive shaft? That would give you and idea of where the end stabbed into the tail housing of the transfer case, and you could compair that to what is showing now. I know when I lifted my 84 K-5 4"'s I too put a 1" drop down on the crossmember. I also remember that it was easy to see where the slip yoke had been (depth wise) in the tail housing. Mine was pretty minimal, so I never did extend the shaft, although I had plans about maybe doing it someday. I never had any problems with it when I was wheeling though. Hope this helps.
