? about 31's - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 06-06-2001, 07:05 PM
? about 31\'s
i was wonder what would be the best way to get a 31 in tire a 11 or 10.50 under a 91 s-10, what kind of lift, just the best way to go with hardly any rubbing. the 2 in supension from superlift sounds good but i have heard alot of bade thing about it. thanks, if any onw has a setup like this could they please post it
post #2 of (permalink) Old 06-07-2001, 01:00 AM
Re: ? about 31\'s
Not sure about when the body change took place, but my 85 blazers has 31x10.5 swampers on it. All I used was a 3 inch body lift. I had to cut out a little of the inner fender and smack the back edge of the front fender with a hammer. It all still looks factory. I do get a bit of tire rub if I get her twisted pretty good or hit a really hard bump. Think I can fix that with a torsion bar tweek. The reason i went with the body lift is to keep the center of gravity a little lower. You only lift the weight of the body instead of the whole truck, plus you are looking at $85 for a body lift compaired to the $1500 - $2000 for a suspention lift. Hope this helps.
post #3 of (permalink) Old 06-11-2001, 06:49 PM
Re: ? about 31\'s
Torsion bar crankup (front) and shackles (rear). For more info, look at www.s10-4x4.com
Kevin
'89 XJ Cherokee, stock.
MIJeepBoy is offline
post #4 of (permalink) Old 06-11-2001, 06:50 PM
Re: ? about 31\'s
Torsion bar crankup (front) for the cost of an alignment and shackles (rear) for $15 at advance auto. For more info, look at www.s10-4x4.com
Kevin
post #5 of (permalink) Old 06-12-2001, 01:31 AM
Re: ? about 31\'s
If you have stock rims the easiest way to fit 31x10.50s would be to crank up the torsion bars and buy the $15 shackles to put on the back. You would only rub your frame or swar bar at full lock. They'd be crammed in there. Or a 2-3" body lift will do the same thing
Heck I've got a 3" body and the tbar lift and I only hit the fender on one side on bumps and turns. (The a-arm bushing is bad so the a-arm moves) I've also got 15x8s so my tires stick out some...
85 S10 Blazer 3" body 2" tbar lift. 31x10.50s on 15x8 rims
My Off-Road Page,
post #6 of (permalink) Old 06-18-2001, 01:35 PM
Re: ? about 31\'s
To be specific, http://S10-4X4.COM/HitFit/. If you click on "Technical" in the menu that will bring you to all the tech articles there is an article that goes into depth about the T-bar crank ("easy 2-3" lift I think it's called).
Good luck
He who toots his own horn is talking out of his A$$.
