MSD Ignition Installation (now w/ pics) - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-18-2001, 11:26 AM Thread Starter
Well, got my stuff yesterday. I got the 8.5mm plug wires that were for 92-97 4.3, but they worked fine on my 89. I also got a blaster 2 canister coil. well, i didn't realize how the top was differend. luckly, there was a place close by (30 min.) that sells MSD stuff, so i went there and they made me a new coil wire with the correct end on it. I then installed the 6A box by the supplied directions. It fired right up. haven't driven it tho, there is a puddle of ATF under my truck for some reason... ill try to get some pics this weekend where i installed all the stuff at. I also have to regap my plugs, they suggest .060. if you want any part numbers let me know.
Craig
'89 S-10 P/U 4.3L 31" Yoko M/Ts (For Sale!)[img]/wwwthreads_images/icons/shocked.gif[/img]
'99 S-10 2.2L 2WD 5 Speed Stepside Totally Stock [img]/wwwthreads_images/icons/frown.gif[/img]
'88 Kawasaki Mojave (FOR SALE)[img]/wwwthreads_images/icons/cool.gif[/img]
Fishyoo7 is offline
post #2 of (permalink) Old 05-18-2001, 03:54 PM
Re: MSD Ignition Installation
sounds like you got the ignition going
as far as the Trannie leak you may have a bad frount seal in the trannie My 89 I had had the same problem with the frount seal replace it and you should be fine from there while your at it it would probably be a good idea to change the fluid and filter for good measure
Nissan_King_84
1984 Nissan King Cab 4x4
http://www.geocities.com/nowheres/Paul_s_720_Page.html
Nissan_King_84 is offline
post #3 of (permalink) Old 05-19-2001, 11:07 AM Thread Starter
Re: MSD Ignition Installation (now w/ pics)
here is a pic of under the hood where i mounted everything...it is the only clean stuff, and it is red.
Craig
Fishyoo7 is offline
post #4 of (permalink) Old 05-19-2001, 11:08 AM Thread Starter
screwed that one up...
Craig
Fishyoo7 is offline
post #5 of (permalink) Old 05-19-2001, 11:12 AM Thread Starter
here is the blaster 2 coil mounted
Craig
Fishyoo7 is offline
post #6 of (permalink) Old 05-19-2001, 11:12 AM Thread Starter
here is the box mounted
Craig
Fishyoo7 is offline
post #7 of (permalink) Old 05-19-2001, 04:03 PM
Hi, can you put oil in the engine with the coil placed there ?
btw there is a new oil filler plug (screw on type) available - the old plug type plug likes to harden and break off and fall in the engine - mine did.
Greetings from Austria
