Clunk in stearing - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 05-13-2001, 07:29 PM Thread Starter
Clunk in stearing
I just installed a 2 inch lift on my blazer and now I notice a small clunk when stearing about a 1/2 turn left and right of center. I can barely feel it on the wheel and it can only be heard sometimes. Should I worry about this or is it just working it's self in from the shaft being extended?
If it has wheels or a skirt,
You can't afford it!
Berg84 is offline
post #2 of (permalink) Old 05-13-2001, 09:23 PM
Re: Clunk in stearing
Might want to see if the steering wheel is binding anywhere at all when you turn it, by having a friend turn the wheel and then checking the shaft as it rotates. Good idea to do this soon before it gets worse and becomes a bigger problem for you!
[img]/wwwthreads_images/icons/smile.gif[/img]
http://members.nbci.com/desertride/index.htm
J.R. is offline
post #3 of (permalink) Old 05-14-2001, 02:59 AM
I had a 89 GMC Jimmy a few years ago that i put a 3" body lift on it and had the same prob you are Discribeing
Heres what I found the problem to be in the engine compartment where the steering shaft comes throught the firewall there is a universal joint on the shaft that joint in my opinion was poorly designed and isn't open enough for a tighter angle then stock and rubs on itself after the lift you can either drive it for several months till it wears itself for clearence otr you can take a die grinder and shave a little material of the joint where it is binding for clearence or You can try getting the joint off a toyota truck (approx an 85) and try mateing it onto your stering shaft
The toyota joint can handle almost a 90 degree angle with out binding up
Nissan_King_84
1984 Nissan King Cab 4x4
http://www.geocities.com/nowheres/Paul_s_720_Page.html
Nissan_King_84 is offline
post #4 of (permalink) Old 05-14-2001, 10:48 AM Thread Starter
It isnt' that big of a deal. Nothing seems to be binding and the shaft doesn't shake when it clicks. Also it only happens some of the time. Not always. I think I'll wait it out.
Berg84 is offline
