Code #15 - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-22-2001, 07:26 PM
H_BONE
Code #15
Hey fellas anbody know anything about a Code #15 engine coolant sensor. I drive a 88 GMC (Good Mountain Climber) 4.3 TB injected. The truck dose not run hot at all. When im off road boggin the truck will sometime start running like crap. I unhook the battery and proceed on with out problems. This only happen every month or so. The truck acts like it has a fuel systems problem to me. I put a new in-line fuel filter on with no help. I think it might be the O2 sensor. This is not a big problem, I just thought I would ask some of you high speed mechanics out there. Thanks
88 GMC Ex. Cab 4.3 TBI 5 in. stage west lift 2 in. body
4:10's turn 33 boggers X8000i multi mount Warn
post #2 of (permalink) Old 04-23-2001, 02:35 PM
Re: Code #15
If it is the same as an '89 S-10 then the #15 means that the ECM coolant sensor (2 wires near thermostat) is indicating low temp. Maybe its connections are bad?
On the passenger side you have the coolant sensor for the gauge ( 1 wire).
Greetings from Austria
post #3 of (permalink) Old 04-24-2001, 12:06 PM
Re: Code #15
herribert is right on the code suggest check the wireing make shure everything is is good shape then Disconnect wires and clean the connectionds real good and see if that helps if not Replace the Coolent sensor
Nissan_King_84
1984 Nissan King Cab 4x4
http://www.geocities.com/nowheres/Paul_s_720_Page.html
Nissan_King_84 is offline
