tire and 2.8 question - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-16-2001, 09:43 PM
Does anyone know what the max tire size is without a lift? Also I am in the process of changing my 2.8 motor out. I am replacing it with a 2.8 motor out of a 1987 camaro,my s-15 jimmy is 1984.Does anyone forsee any problems,and what do I do about them?
post #2 of (permalink) Old 04-16-2001, 10:34 PM
Re: tire and 2.8 question
I have a 89 S-10 and can run 30 X 9.50's with no problem but I think any larger than that you will need a lift.
post #3 of (permalink) Old 04-16-2001, 10:57 PM
<font face="Comic Sans MS">Maximum tire size I would go is 235/75/r15's with 3.73 gears. With 4.10 gears I would try for a bit bigger. [img]/wwwthreads_images/icons/crazy.gif[/img] At least with the 2.8L... [img]/wwwthreads_images/icons/crazy.gif[/img] Just doesn't have the low end grunt I'd prefer... [img]/wwwthreads_images/icons/crazy.gif[/img] (I have 235/75's and 3.73's)... [img]/wwwthreads_images/icons/crazy.gif[/img] Check the mounts on the camaro engine to make sure they're the same. Why don't you go for a newer camaro with the 3.4L? Much better choice. [img]/wwwthreads_images/icons/crazy.gif[/img] Same bellhousing bolt pattern, etc... Need to grab the flywheel from the camaro you pull a 3.4L from though... There are other posts on the topic... Search works good... </font>
Tim "Sandman"
ORC Land Use columnist:
My February article on ORC
(I'm finally back)
The_Sandman_454 is offline
post #4 of (permalink) Old 05-01-2001, 09:55 PM
Thanks for the inputs.I believe, I will be going with the 30*9.50*15 BGF's.I took the 2.8 motor out the 87 camaro,because it was my cusins (everything shot but motor ,it was in great shape).I only have a few more things to do.Then I will be though,THANK GOD.
post #5 of (permalink) Old 05-01-2001, 10:21 PM
I hope you got the computer out of the Camaro also as its 2.8L is Multi-Port where the S10s were TBI. Sounds like a pretty good swap, though.
A.S.
1989 GMC S-15 4x4 4.3L/700R-4, 3.08s, 31" Sport Kings For Sale
1985 S-10 4x4 Soon to have 3504BM/TH350/D44/14FF, 35" Boggers
post #6 of (permalink) Old 05-07-2001, 09:36 PM
Thanks for the heads up.I took the fuel-injection system off ,and replaced it with my old carb system.Also another thing I had to change the timing-chain cover,with my old cover.
