TB crank up - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 04-15-2001, 11:18 PM
TB crank up
I'm not looking for a sky-high ride, but I am wanting an inch or two above stock. So is doing the TB crank/add a leaf lift worth it or should I shoot for a superlift kit or something like that? (I've heard nothing but trouble with the superlift kits and the like) If the TB crank is worth it, how much can i turn them up without having to replace front end components all the time? Also how much bigger of a tire will I be able to fit, and will I need new shocks?
Thanks for the help.
Honda Civics make good parking spots!
post #2 of (permalink) Old 04-16-2001, 03:10 PM
Re: TB crank up
Tell you what Put a 3" body lift on there thenyou will have the room to Clear 31/10.5x15's
If you feel like trimming the fenders You can also put 33's on the s-series but you will be takeing Alot of metel of to Clear the tires You have to Make shure the opening on the fenders (at the bottom) are no Smaller then 36" to Clear the 33's with no problems
Personally I would leave the stock suspention Alone
If you insist on messing with the Tortion Bars I wouldn't go more then an inch with Shackels or blocks in the back to Match
Nissan_King_84
1984 Nissan King Cab 4x4
http://www.geocities.com/nowheres/Paul_s_720_Page.html
Nissan_King_84 is offline
post #3 of (permalink) Old 04-16-2001, 11:41 PM
Re: TB crank up
First, cranking up your torsion bars does absolutely NOTHING for suspension travel. All it will do is put extra strain on the CV joints (although you will be hard pressed to find anyone who will tell you it has happened - or at least will admit to it!).
This is sort of a comparison to apples and oranges... Cranking up your torsion bars only will gift you a little clearance for tires, but will make your ride rougher and "bouncier". You are, in effect, changing the spring rate of the front end to be more responsive. This can wear out shocks and CV joints more quickly than stock height.
A "lift kit" only provides you will a drop bracket for the front end and will usually come with some kind of longer a-arm, either upper or lower, or both. This doesn't even really give you much travel either, but some. After that you are just, again, cranking up the torsion bars to get lift. The drop bracket for the front end is the key, as it will keep your CV joints and stub axles more in line.
Sorry this is long, but I have feeling that most folks aren't getting the difference between cranking up the T-bars and a "lift kit".
By the way, I use "lift kit" as a generic term. If I had the knowledge and expertise (oh, and money), I'd be running longer a-arms, bigger torsions, reservoir shocks and pre-runner rear springs...
But I might just end up getting another truck!
http://members.nbci.com/desertride/index.htm
J.R. is offline
