well crap... - Off-Road Forums & Discussion Groups
post #1 of (permalink) Old 03-06-2001, 01:45 AM
well crap...
darned truck died on me - went to the local gas station and sputter died
im figuring its either the coil or the carb - coil wasnt replaced with the engine and the carb needed to be rebuilt and i was gonna get to it soon
well i guess im getting to it sooner than later - im gonna put a high energy coil and get the carb rebuilt
i also ordered the 3 inch body lift kit from TM for it and next is the 5 inch suspension lift - im gonna have the baddest S-10 in TN
Richard
85 S-10 3.4L cat-back exhaust otherwise stock for now
post #2 of (permalink) Old 03-06-2001, 02:37 AM
Re: well crap...
<font face="Comic Sans MS">Get an inductive timing light. Clamp the inductive lead onto any spark plug wire or the coil wire (secondary wire, not the primaries), hook the power cables up, and have someone crank the engine while you press the trigger on the timing light. If it flashes then you're getting spark and the coil isn't your problem.
When was the last time you checked the fuel filter? Is the fuel pump operating? Pull the fuel line at a good point and see if it's flowing enough. Did the truck flood out?
Check the condition of the plugs, wires, cap and rotor. The rotor might be burned through causing the spark energy to go right to ground.
Another very real possibility, especially if the spark shorted to ground through the rotor or similar path, is the ignition module. If you're not getting spark, you should have the module tested, some parts stores can do that (or it wouldn't be too expensive (about $10 or $15) to procure a new module to try it out. If you find that your old module was ok, toss that one back in and keep the new one in the glovebox for a spare... [img]/wwwthreads_images/icons/crazy.gif[/img]</font>
Tim "Sandman"
ORC Land Use columnist:
My February article on ORC
(I'm finally back)
The_Sandman_454 is offline
post #3 of (permalink) Old 03-07-2001, 01:14 AM
Re: well crap...
well the shop is gonna do all that about the coil
fuel filter was replaced with the motor - its frame mounted instead of the stock location
the distributor and all is new except the coil - like i said the shop will see to all that
all comes with buying an older truck
Richard
